Export settings / "Tools" missing in menu
HWitche
New York
Eventually I want to export my settings to import it to another computer,
but I can't find "Tools" in the menu, I have "Toolbars" but not "Tools". Very weird.
OS Windows 7
Thank you for your help
Hans
Reply with quote E-mail
HWitche
New York
OMG found it
OMG
I found it, it's just very very hard to find:
only available in the > "New Session" window !
I could imagine to have it also in the main menu...
thanks
Hans
Re: Export settings / "Tools" missing in menu
Thanks for your feedback. How did you know you should look for "Tools"?
If you read it in the documentation, it states that you should look at the Login dialog:
https://winscp.net/eng/docs/config#export
Though indeed, we might want to move it elsewhere. The current location is historical, from times, when the Login dialog popped up even before the main window. What is no longer true.
HWitche
New York
"Tools" difficult to find, if many sessions open
Hi Martin,
I had about 10 sessions open and was not thinking of going to open "New Session", where the "Tools" tab is. So I was a bit lost, but finally found it. I made a note where to find it next time exporting my settings.
Thanks, have a great day
Hans
