Synchronization Checklist - Reorder
I think it would be very helpful to change the order of rows in the Synchronization Checklist.
The default order seems to be ascending alphabetical by Directory then Name column. I'd like to reorder on the Size or Changed columns.
I've no idea how easy/difficult this would be to implement but the usual method of clicking on a column heading to reorder by that column would be great. Also clicking on the column heading again would switch between ascending/descending order.
Thanks for a great product.
Tom.
Synchronization Checklist - Reorder - Thank you
Many thanks for implementing this in 3.8.1
It seems like a small feature, but getting all the little things right add up to great product in WinSCP.
This will help me synchronize a document repository with over 83000 files (13GB) in a single directory.
Thanks again,
Tom.
