Chinese file names are not supported
Re: Chinese file names are not supported
cjchome
I use "SCP" protocol login, WinSCP can not supported Chinese file names
I use "SFTP" protocol login, WinSCP can supported Chinese file names
From the log:
> 2021-04-22 09:53:40.519 printenv LANG ; echo "WinSCP: this is end-of-file:$?"
! 2021-04-22 09:53:40.522 -sh: printenv: not found
< 2021-04-22 09:53:40.526 WinSCP: this is end-of-file:127
Try forcing UTF-8 in session settings:
https://winscp.net/eng/docs/faq_utf8#scp
https://winscp.net/eng/docs/ui_login_environment#utf
Previous versions, the Chinese filenames can be displayed normally in WinSCP "SCP" protocol.
But 5.18.3 RC, I tried set UTF-8 encoding for filenames option Auto/On/Off, WinSCP still can't display Chinese filenames.
And I turn On/off Control Panel > Clock and Region > Region > Administrative > Language for non-Unicode programs, it's still the same. Pls kindly check again, thanks
