No connection could be made because the target machine actively refused it
ry
afrique
Hi I'm new in this forum. I'll be thankful if there is someone who can help me.
I'm using vsftpd on my ubuntu 20.04 !
I tested at the first vsftpd without SSL with active mode. It worked fine! But when I enabled my SLL with active mode I get an error to pass to the passive mode! So I passed to passive mode and I add in my /etc/vsftp.conf:
vsftpd_log_file=/var/log/vsftpd.log
tcp_wrappers=YES
pasv_enable=Yes
pasv_min_port=40000
pasv_max_port=50000
pasv_address=51.91.250.89
allow_writeable_chroot=NO
user_sub_token=$USER
local_root=/home/$USER/ftp
userlist_enable=YES
userlist_file=/etc/vsftpd.userlist
userlist_deny=NO
this is my firewall status !
root@VPS:/# sudo ufw status
Status: active
To                         Action      From
Nginx HTTP                 ALLOW       Anywhere
20:21/tcp                  ALLOW       Anywhere
40000:50000/tcp            ALLOW       Anywhere
Nginx HTTP (v6)            ALLOW       Anywhere (v6)
20:21/tcp (v6)             ALLOW       Anywhere (v6)
40000:50000/tcp (v6)       ALLOW       Anywhere (v6)
and if I test my vsftpd server in WinSCP i get this error !
. 2021-04-15 12:43:51.167 Using FTP protocol.
. 2021-04-15 12:43:51.167 Doing startup conversation with host.
> 2021-04-15 12:43:51.183 PWD
< 2021-04-15 12:43:51.245 257 "/" is the current directory
. 2021-04-15 12:43:51.245 Getting current directory name.
. 2021-04-15 12:43:51.293 Retrieving directory listing...
> 2021-04-15 12:43:51.293 TYPE A
< 2021-04-15 12:43:51.339 200 Switching to ASCII mode.
> 2021-04-15 12:43:51.339 PASV
< 2021-04-15 12:43:51.402 227 Entering Passive Mode (51,91,250,89,188,92).
> 2021-04-15 12:43:51.402 LIST -a
. 2021-04-15 12:43:51.402 Connecting to 51.91.250.89:48220 ...
. 2021-04-15 12:43:52.589 Transfer channel can't be opened. Reason: No connection could be made because the target machine actively refused it.
. 2021-04-15 12:43:52.605 Could not retrieve directory listing
. 2021-04-15 12:43:52.605 LIST with -a failed, will try pure LIST
. 2021-04-15 12:43:52.605 Retrieving directory listing...
> 2021-04-15 12:43:52.605 TYPE A
. 2021-04-15 12:44:07.809 Timeout detected. (control connection)
. 2021-04-15 12:44:07.809 Could not retrieve directory listing
* 2021-04-15 12:44:07.880 (EFatal) **Lost connection.**
* 2021-04-15 12:44:07.880 Timeout detected. (control connection)
* 2021-04-15 12:44:07.880 Could not retrieve directory listing
* 2021-04-15 12:44:07.880 Error listing directory '/'.
I don't know what to do ???
Reply with quote E-mail
Re: No connection could be made because the target machine actively refused it
Is the 51.91.250.89 an IP address of your server?
Anyway, this is not really WinSCP question (unless other FTP clients work). Consider asking at an appropriate site, like https://superuser.com/.
ry
yes this is the ip :(
i posted in superuser but no one answer me ! and i really need help please
