Batch file to upload files created today
natchiram
Hi, I am trying to put a file into a remote location and delete it after the upload process completes. It is failing with this error
(ExtException) **Copying files to remote side failed.**
I have attached the log file.
The script that I am using is as below:
  /log="C:\WinSCP\WinSCP.log" /rawconfig Logging\LogFileAppend=0 /ini=nul /command ^
    "open ftp://username:password@ip address:port/" ^
    "cd /remote directory" ^
    "lcd ""local directory""" ^
    "put -filemask=*>=today ""Local directory\*"" -delete" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Regards,
Ram
Re: Batch file to upload files created today
natchiram
I am not able to see the folders from any of the FTP clients but can navigate to that folder using the credentials in the Windows Explorer. Also, I can transfer the file manually using a simple cmd line script as below, but there are some conditions that I need to add, such as file size, date of creation, which is why I am using WinSCP.
Drive:
cd\path
ftp
OPEN host port
username
password
cd remote location
PUT filename
CLOSE
QUIT
natchiram
Sorry for the delay. After adding the switch -passive=off, the script worked fine.
Thank you very much for your help.
The modified script is as below:
    "open ftp://username:password@ip address:port/ -passive=off" ^
    "exit"
  echo Success
) else (
  echo Error
dipesht@...
Batch file error
    "exit"
  echo Success
) else (
  echo Error
