WinSCP with Secure Credentials
hroberts65616
I have this script running beautifully with 5.17.10 Automation to upload a file to a server.
My question is and I tried to search for this, is it possible to use a credential file with WinSCP? Either a password in secure text or by using a credential file in xml.
If so how would I add that into the script.
#Load WinSCP .NET assembly
Add-Type -Path "C:\local path\WinSCPnet.dll"
# Set up session options
    HostName = "host or IP address"
    UserName = "username"
    Password = "password"
    SshHostKeyFingerprint = ""
try
    # Connect
    # Transfer files
    $session.PutFiles("C:\\localFile.csv", "/remote directory/*").Check()
finally
    $session.Dispose()
hroberts65616
USA
I tried the steps in this page:
I tried to follow the steps in this page: https://winscp.net/eng/docs/guide_protecting_credentials_for_automation#powershell
However I am not getting it to work. I have tried it with an XML file and with a CLixml file. I can not get winscp to accept either for me to not have the password in plain text.
Im fairly new to Powershell, but have been scripting on the Linux side for many years.
Thanks all
Re: I tried the steps in this page:
I'm sorry, but you didn't tell us anything about the problems you are facing. Without any information, all I can do is to repeat everything that's written in the linked article already.
