Scheduled Task fails, Manual Execution Successful
grafix23
Created an exe file that is scheduled with Windows Task Scheduler in Windows Server 2016. When scheduled, the applications executes correctly until the WINSCP connection, when the process logs a failure when the connection is opened:
3/29/2021 7:31:15 PM: WinSCP.SessionRemoteException: Connection failed.
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Connection failed.
   at WinSCP.SessionLogReader.Read(LogReadFlags flags)
   at WinSCP.ElementLogReader.Read(LogReadFlags flags)
   at WinSCP.SessionElementLogReader.Read(LogReadFlags flags)
   at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags)
   at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags)
   at WinSCP.Session.WaitForGroup()
   at WinSCP.Session.Open(SessionOptions sessionOptions)
   at ConsoleApplication1.Module1.Main() in C:\Projects\Module1.vb:line 192
If run interactively, the applications runs as expected, including opening the connection and uploading via WINSCP with no issues. Both the interactive user and the Scheduled Task user are local administrators on this server.
Re: Scheduled Task fails, Manual Execution Successful
Please attach a full session log files from both scheduled and manual runs.
Did you try connecting to the server using plain .NET Socket class?
