How do I create a executable Script?
I'm new with WinSCP and I want to create a executable Script. By this, I mean that, if you click on it, it will automatically open the console and type in the command, that is set in the script. This is, because i want to put it then into the autostart folder, so it starts, whenever i start the computer. Is this even possible?
Thanks in Advance
Thanks in Advance
