issue when transferring large files via ftp
jenjk31
While a session is opened and in main window view, drag and drop a file larger than 10MB to transfer from local to remote drive via FTP. At first it looks like it's working but transfer speed rapidly drops and then completely stalls. The error I keep getting is "Timeout detected. (control connection). Copying files to remote side failed". It then automatically tries to reconnect and continue but the same thing happens until I press the "abort" button. I've tried increasing the timeout limit but it doesn't help. Small files <10MB seem to transfer just fine; only the larger ones give this error.
Using WinSCP 5.17.10 with GUI interface on Windows 10 Enterprise 1909.
I re-downloaded the previous WinSCP version, 5.17.9, and this works fine, no errors, for files of any size.
Re: issue when transferring large files via ftp
Please attach a full session log files from both versions.
