When running a script remote directory changes to my documents on its own
petersonvince70@gmail.com
Boise Idaho
Team,
I am working with a very simple script. When I execute the script it keeps trying to change the remote directory to my local documents folder. This only happens on Windows server 2019. I do not have this issue on Windows 10 or Windows Server 2012. Any advice would be most helpful.
winscp Version: 5.17.10
Server: Windows server 2019 standard.
Script:
winscp.com /command "open sftp://xx:xx@xx.net/DEV/IN" "put D:\Files\out\My.csv" "exit" >MyLog.log
Log:
Searching for host...
Connecting to host...
Authenticating...
Using username "xx".
Authenticated.
Starting the session...
Session started.
Error changing directory to 'C:\Users\xx\Documents'.
System Error.  Code: 2.
Re: When running a script remote directory changes to my documents on its own
One possible explanation is that you have a stored session called xx:xx@xx.net (or similar) in WinSCP GUI on that machine, which has that directory configured as the default local one.
You should use /ini=nul commandline switch to isolate the script from the configuration to avoid these kind of issues.
See https://winscp.net/eng/docs/scripting#configuration
See also https://winscp.net/eng/docs/faq_environment
If this does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
