unable to download file via SFTP
_timbo_
There is an external server which I'm connecting to via SFTP. I can connect fine using the GUI, view files, and download them.
When trying to download from code I get the dreaded error code 4. I can connect and ListDirectory fine, but get an error whether trying to GetFiles all at once, or one at a time.
This is everything from the log up to the first Error Code 4.
Any ideas?
[2021-03-26 11:55:42.749] [0001] .NET Framework build
[2021-03-26 11:55:42.749] [0001] Executing assembly: WinSCPnet, Version=1.6.5.10071, Culture=neutral, PublicKeyToken=2271ec4a3c56d0bf
[2021-03-26 11:55:42.749] [0001] Executing assembly codebase: file:///C:/Programs/FileTransfers/WinSCPnet.DLL
[2021-03-26 11:55:42.749] [0001] Executing assembly location: C:\Programs\FileTransfers\WinSCPnet.dll
[2021-03-26 11:55:42.749] [0001] Entry Assembly: FileTransfers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
[2021-03-26 11:55:42.749] [0001] Operating system: Microsoft Windows NT 6.2.9200.0
[2021-03-26 11:55:42.749] [0001] Timezone: 00:00; GMT Standard Time
[2021-03-26 11:55:42.749] [0001] User: xxxxxxxxxxxxx; Interactive: True
[2021-03-26 11:55:42.749] [0001] Runtime: 4.0.30319.42000
[2021-03-26 11:55:42.749] [0001] Console encoding: Input: Western European (DOS) (850); Output: Western European (DOS) (850)
[2021-03-26 11:55:42.749] [0001] Working directory: C:\Programs\FileTransfers
[2021-03-26 11:55:42.749] [0001] Assembly path: C:\Programs\FileTransfers\WinSCPnet.DLL
[2021-03-26 11:55:42.749] [0001] Assembly product version: 5.15.9.0
[2021-03-26 11:55:42.796] [0001] Session.GetFiles entering
[2021-03-26 11:55:42.796] [0001]   Command: [get  -nopermissions -preservetime -transfer="binary" -- "processing//processing/000000000013 (1).TXT" "C:\Temp\"]
[2021-03-26 11:55:42.796] [0001]   ExeSessionProcess.ExecuteCommand entering
[2021-03-26 11:55:42.796] [0001]   ExeSessionProcess.ExecuteCommand leaving
[2021-03-26 11:55:42.796] [0001]   SessionLogReader.Read entering
[2021-03-26 11:55:42.796] [0001]     Waiting for log update and dispatching events for 50
[2021-03-26 11:55:42.796] [0001]     Output: [winscp> pwd]
[2021-03-26 11:55:42.796] [0001]     Output: [/]
[2021-03-26 11:55:42.796] [0004] Scheduling output: [winscp> get  -nopermissions -preservetime -transfer="binary" -- "processing//processing/000000000013 (1).TXT" "C:\Temp\"]
[2021-03-26 11:55:42.796] [0001]     Output: [winscp> get  -nopermissions -preservetime -transfer="binary" -- "processing//processing/000000000013 (1).TXT" "C:\Temp\"]
[2021-03-26 11:55:42.796] [0004] Releasing communication structure
[2021-03-26 11:55:42.796] [0004] Released communication structure
[2021-03-26 11:55:42.796] [0004] 2nd generation collection count: 1
[2021-03-26 11:55:42.796] [0004] Total memory allocated: 5251504
[2021-03-26 11:55:42.796] [0004] Waiting for request event
[2021-03-26 11:55:42.827] [0004] Got request event
[2021-03-26 11:55:42.827] [0004] ExeSessionProcess.ProcessEvent entering
[2021-03-26 11:55:42.827] [0004]   Acquiring communication structure
[2021-03-26 11:55:42.827] [0004]   Acquired communication structure
[2021-03-26 11:55:42.827] [0004]   Print: 000000000013 (1).TXT      |            0 B |    0.0 KB/s | binary |   0%
[2021-03-26 11:55:42.827] [0004]   Buffered from-beginning message [000000000013 (1).TXT      |            0 B |    0.0 KB/s | binary |   0%]
[2021-03-26 11:55:42.827] [0004]   Got incomplete progress output
[2021-03-26 11:55:42.827] [0004]   Releasing communication structure
[2021-03-26 11:55:42.827] [0004]   Released communication structure
[2021-03-26 11:55:42.827] [0004] ExeSessionProcess.ProcessEvent leaving
[2021-03-26 11:55:42.827] [0004] 2nd generation collection count: 1
[2021-03-26 11:55:42.827] [0004] Total memory allocated: 5267888
[2021-03-26 11:55:42.827] [0004] Waiting for request event
[2021-03-26 11:55:42.859] [0001]     Read 168 bytes from log
[2021-03-26 11:55:42.859] [0001]     Read node 20: Whitespace
[2021-03-26 11:55:42.859] [0001]     Log contents:
<?xml version="1.0" encoding="UTF-8"?>
<session xmlns="http://winscp.net/schema/session/1.0" name="xxxxxxxx@xxxxxxxxxxxxxx" start="2021-03-26T11:55:40.249Z">
  <group name="open sftp://F30788AB:***@xxxxxxxxxxxxxx:22 -hostkey=&quot;ssh-rsa 2048 5zt6BTseLlT+Cs5cnp8PBjQwM/dLa738BeXSsHeCaag=&quot; -timeout=15" start="2021-03-26T11:55:42.078Z">
  </group>
  <group name="pwd" start="2021-03-26T11:55:42.749Z">
    <cwd>
      <cwd value="/" />
      <result success="true" />
    </cwd>
  </group>
  <group name="get  -nopermissions -preservetime -transfer=&quot;binary&quot; -- &quot;processing//processing/000000000013 (1).TXT&quot; &quot;C:\Temp\&quot;" start="2021-03-26T11:55:42.796Z">
[2021-03-26 11:55:42.859] [0001]   SessionLogReader.Read leaving
[2021-03-26 11:55:42.859] [0001]   SessionLogReader.Read entering
[2021-03-26 11:55:42.859] [0001]     Read 25 bytes from log
[2021-03-26 11:55:42.859] [0001]     Read node 21: Element group
[2021-03-26 11:55:42.859] [0001]     Log contents has not changed
[2021-03-26 11:55:42.859] [0001]   Session.CreateProgressHandler entering
[2021-03-26 11:55:42.859] [0001]   Session.CreateProgressHandler leaving
[2021-03-26 11:55:42.859] [0001]     Waiting for log update and dispatching events for 50
[2021-03-26 11:55:42.921] [0001]     Waiting for log update and dispatching events for 100
[2021-03-26 11:55:42.937] [0004] 2nd generation collection count: 1
[2021-03-26 11:55:42.937] [0004] Total memory allocated: 5325220
[2021-03-26 11:55:42.937] [0004] Waiting for request event
[2021-03-26 11:55:43.031] [0001]     Waiting for log update and dispatching events for 200
[2021-03-26 11:55:43.046] [0004] 2nd generation collection count: 1
[2021-03-26 11:55:43.046] [0004] Total memory allocated: 5333400
[2021-03-26 11:55:43.046] [0004] Waiting for request event
[2021-03-26 11:55:43.062] [0004] Got request event
[2021-03-26 11:55:43.062] [0004] ExeSessionProcess.ProcessEvent entering
[2021-03-26 11:55:43.062] [0004]   Acquiring communication structure
[2021-03-26 11:55:43.062] [0004]   Acquired communication structure
[2021-03-26 11:55:43.062] [0004]   Print:
Copying files from remote side failed.
Error code: 4
Error message from server:
Common reasons for the Error code 4 are:
- Renaming a file to a name of already existing file.
- Creating a directory that already exists.
- Moving a remote file to a different filesystem (HDD).
- Uploading a file to a full filesystem (HDD).
- Exceeding a user disk quota.
Re: unable to download file via SFTP
Can you download those files anyhow? In WinSCP GUI? In any other SFTP client?
_timbo_
I have noticed today that the host has a \processing subfolder. I cannot download from this, but I can download from the root folder using the GUI.
I have tried comparing the settings in the GUI with the property settings in the API but can't notice any obvious differences.
I am unable to download from the root folder using the API, I have attached the log. Is it possible that the API is recursive and is failing due to the processing folder?
Thanks,
Tim
  • ftp_0876d229-59b9-498e-bb30-98224bb2095c.log (14.53 KB, Private file)
_timbo_
As a further update, rather than risking any recursive action I have also listed the files successfully via the API but then it still fails to download a single named file (log attached for both the list and the get).
Thanks for your help.
Tim
  • ftp_709a3bad-b8bf-4f97-9338-69a3a72310b3.log (45.22 KB, Private file)
  • ftp_ea39332b-0600-43bf-9e3a-d70728c15e38.log (14.76 KB, Private file)
Neither of the three debug logs you have posted show any file transfer.
And I've asked for a session log file anyway.
Additionally please post a session log file from GUI showing the successful transfer.
