Is it possible to disable the "encrypt new file" feature when loading files to a SFTP via PS Script
desmondkan
as subject.
I have a powershell script that does the upload some pgp files to a SFTP site. the other party is having issues to open the pgp files and I noticed the winscp does "encrypt new file" by default. My question ... is it possible to disable the feature of "encrypt new file" in the powershell script? i believe there are some switch or command lines that I can specify in the powershell to disable it ?
my winscp version is 5.17.1 (build 10240).
Thanks for your help in advance.
-d
desmondkan
yes, I noticed it has "encrypt new file" feature as a default option. I also know it has nothing to do with PGP files. My situation is that I use PowerShell script to initiate winscp to do the upload and my question is it possible to disable "encrypt new file" in the powershell script so winscp will do the job without the feature of "encrypt new file" ?
Re: Is it possible to disable the "encrypt new file" feature when loading files to a SFTP via PS Script
See https://winscp.net/eng/docs/rawtransfersettings#encryptnewfiles
$transferOptions.AddRawSettings("EncryptNewFiles", "0")
$session.PutFiles($source, $dest, $False, $transferOptions).Check()
WinSCP GUI can generate such code template for you:
https://winscp.net/eng/docs/guide_automation#generating
desmondkan
got it. thanks for sharing the info.
I will give it a try ... thanks Martin :)
