Synchronise FTP
Holly
Synchronise FTP
Hi
I'm struggling with getting the remote (FTP) folder to sync back to the local folder.
If I make a change in the remote (FTP) folder, delete a file or add etc, what option needs to be checked for it to sync the change to the local folder automatically?
It syncs the change from the local folder to the remote, the 'both' option is checked
Holly
Re: Synchronise FTP
Hi, sorry I should have been a bit clearer. I need it to sync both ways, automatically if possible? At the moment, even though I have 'both' selected it only syncs from local to the remote FTP automatically not from the remote FTP to the local folder
Thanks for your help
Re: Synchronise FTP
Please attach a full session log file showing the problem (using the latest version of WinSCP). Mention a specific file that you believe should have been synchronized and was not.
