Support to browse drive letters that have been hidden?
upsidedown
I have hidden certain drive letters from showing on Explorer using the registry in:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
Being the registry key:
NoDrives
But because they are hidden from the default file explorer it is also hidden from WinSCP, I understand that I shouldn't be able to see the drive in the drive list, that's what I want, but I should be able to access the drive if I access it manually by entering its letter or the path to a directory inside one of the hidden drives, instead WinSCP does nothing when I try that. Can you please add support or fix this? I'm on Windows 10.
Thank you.
Nilpo
New Springfield, OH
Try using Ctrl+O or choosing Go To > Open Directory from either the Local or Remote menu depending on which side you want. You can type in your desired directory path.
Re: Support to browse drive letters that have been hidden?
@upsidedown: We will see, if more people ask for this.
Btw, the suggestions by @Nilpo cannot work. But you probably know that already.
What you can do is to create a directory symlink on one of the visible drives. Or use an UNC path to access those drives.
