WinSCP version 5.17.10 installation error
jrandolph68
I am getting the following error message when installing WinSCP
WinSCP: SFTP, FTP, WebDAV, S3 and SCP client have stopped working
A problem caused the program to stop working correctly. Please close the program and try again.
Windows Event Viewer gives this exception code: 0xc0000005. I can reboot the machine into safe mode and launch the program with no problem or errors. It works just fine in safe mode. I really need a resolution to this problem as we have 45 VM's that are power users of this app.
Re: WinSCP version 5.17.10 installation error
So are you getting the problem when installing WinSCP or when starting WinSCP? Or are you getting the problem, while installing (but the installation completes nevertheless), and then again when starting the installed WinSCP?
jrandolph68
I am having the problem when installing. The installation completes and shows installed in Programs and Features, but won't launch. It only started when we upgraded our systems from 1809 to 1909. If we create new VM's with 1909 image, WinSCP works fine. It is only happening with the in place upgrade on currently live machines.
jrandolph68
WinSCP Debug Version
I received the notification about your response but I did not receive the email with the debug version. Please send it to joerandolph68@gmail.com. Thank you.
jrandolph68
So no more responses or support?
Martin, you said you sent me an email about the debugging version. I responded that I never received the email but I did receive the notification that you commented in the forum. I asked you to send to a different address on 3/9/21. Since that time, I have gotten nothing from you. Please address this so I can move forward. Thank you,
Re: So no more responses or support?
I've resent the email to your other address. Please understand, that we are not doing 24/7 support here.
