exclude filesize in synchonization script
guest
I need to exclude a specfic file size in my synchonization script.
Is this a current feature, or one in development?
Thanks,
Re: exclude filesize in synchonization script
Do you mean that you want to exclude all files with certain size? It's not possible and I do not find much use for it to implement it. Sorry.
With filesize concerns on the destination server we need to eliminate uploaded patch.zip files that are larger then 1gig.
Other then excluding *.zip would you have another suggestion?
Thanks,
Scott
p.s. your application is very useful. tks!
