Server´s host key is invalid
James_87
Spain
Cannot connect to a server by SFTP. WinSCP shows the following error:
Server's host key is invalid
How can I solve the issue? I try to connect to another server and works correctly
I´m using WinSCP GUI version 5.17.10 over Windows 10 Pro
Re: Server´s host key is invalid
Can you login with any other SSH/SFTP client? If you can, please post its verbose log file.
James_87
Spain
Attached is the log file from a succesful SSH/SFTP session
  • SBC-CPD1.log (8.25 KB, Private file)
How's that relevant? I did ask you, "if can you login with any other SSH/SFTP client"? Not to any other SSH/SFTP server.
So then please contact your server administrator. This is not a WinSCP issue, but a problem with your server.
