no parent folder [..] in remote view when browsing inside Amazon S3 bucket
p-schneider
The remote side (right side in commander view) does not offer the ".." folder (parent folder) when navigating inside an Amazon S3 bucket (connected using the "Amazon S3" protocol).
I know I can still navigate clicking any of the parent folders in the path line above the folder list, but I think it would be more convenient if the "Amazon S3" protocol would show .. when navigating inside a bucket.
I do get the ".." folders when navigating between buckets (at the hierachy level above the bucket itself), but not when inside a bucket or inside a subfolder within a bucket.
Re: no parent folder [..] in remote view when browsing inside Amazon S3 bucket
Usually the ".." are there. How did you upload the contents to that specific bucket?
