Customer updated Host server resulting in new host key
Jtomalewski
We run a simple batch script using WinSCP to connect to our customer servers and pull files over using private/public key. Recently a customer ran updates in their environment resulting in a new hostkey. Going through the GUI I receive the prompt similar to below, and accept the new key.
https://winscp.net/eng/docs/message_host_key
When connecting through our commandline I receive the error "Server's host key did not match the signature supplied"
Command we're running
"C:\program files (x86)\winscp\winscp.com" /command "option confirm off" "open username@hostname -privatekey=privatekey.ppk"
Output is
confirm      off
searching for host...
connecting to host...
Server's host key did not match the signature supplied.
I've tried adding the -hostkey switch into the open command using every variation of -hostkey=* or -hostkey=""ssh-rsa XXXXXXXXX"". All of which results in the same error. How can I get past this issue.
Description: Screenshot of error
2021-02-11 09_05_35-2021_02_11_09_04_01_pghwrkpv300.agility.prod.nhsinc.net_Remote_Desktop_Connectio.png
Re: Customer updated Host server resulting in new host key
What kind of server is that? What kind of upgrade was it?
