How to install SSL Cert?
shariq.azman
Selangor, Malaysia
Hi Team,
I'm new in this winscp, i has download this Winscp due to Customer requirement, also i already have DIGICERT, my problem is, once i fill up all the data needed such as file protocol, host name, port etc. when i click to login winscp said error code 2 pop up. is there guidance how to sync my SSL Cert with Winscp?
_________________
THANK YOU FOR THE SUPPORT!!
Re: How to install SSL Cert?
Why do you think this has anything to do with the "SSL Cert"?
shariq.azman
Selangor, Malaysia
code as per attachement using .NET assembly code
_________________
  • Set up session options.docx (13.81 KB, Private file)
