Error Scripting to FTP /DataSet
ITGUY1234
I am tasked with creating a script to FTP a file that gets deposited to a vendors DataSet/MainFrame. When I logon to the FTP, I need to go up one folder on their FTP. Then I attempt to drop the file. The thing is, I can transfer the file manually with no issue via the cmd prompt.
I am new at scripting be kind.
I will put the script and the results
Script:
open xxxFTP
ASCII
cd ..
lcd xxxMyLocalSFTP
put -delete xxxFileName
bye
Result:
INFO : Connecting to xxxIP
INFO : Connected
INFO : Starting the session...
INFO : Session started.
INFO : Active session: [1] xxxcreditials
INFO : transfer        ascii
INFO : /''
INFO : xxxMyLocalSFTP
INFO : Using configured transfer settings different from factory defaults.
INFO : xxxFileName |            0 B |    0.0 KB/s | binary |   0%
INFO : Error transferring file 'xxxFileName'.
INFO : Copying files to remote side failed.
INFO :
INFO : CWD cmd failed : EDC5129I No such file or directory. (errno2=0x05190050)
INFO : (A)bort, (R)etry, (S)kip, Ski(p) all: Abort
INFO : Exit code: 1
INFO : Max roundtrip: 0
INFO : Plugin Run Dos Commands completed successfully - 19:19:35 (elapsed time: 00:00:00:775)
INFO : Deleting file : job01092T0P17AWP4DF2E9EC11.dat, size: 249612 bytes
INFO : Plugin Delete completed successfully - 19:19:35 (elapsed time: 00:00:00:000)
Re: Error Scripting to FTP /DataSet
