Host "root" does not exist while doing automation backup using WinSCP
Eric8isles
Malaysia
This is my script to do automation:
option batch abort
open %1% -hostkey="%2%"
synchronize local %3% "%4%"
This is my code to copy the backup from source to destination:
rem S01
winscp.com /ini=nul /script=SyncToLocalScript.txt /parameter sftp://root:xxxxxxxxxxxx@xxx.xxx.xxx.xxx:xx "ssh-ed25519 255 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx=" "D:\Backup\S01VM" //backup/
And this is my error code:
Host "root" does not exist.
The filename, directory name, or volume label syntax is incorrect.
I really need a good automation master to guide me on this.
ps: I checked many times on the credential the server protocol information and there is no error on credential and SPI. I even can log in manually by WinSCP but when it comes to this automation script, the error came out. Plus, there is no error on my other backup from another server(same script)
Please help me.
Reply with quote E-mail
Re: Host "root" does not exist while doing automation backup using winSCP
The error has been shown as above. and the rest full session log is the credentials and attempts to log.
That's not a log. That a console output. My post above details how to collect the logs.
