Transfer files from Windows to Linux
saikarthik.vempati
USA
I'm trying to create a batch file to automate the process of log transfer of logs from Windows server to Linux server using WinSCP commands for logs that are greater than or equal to 1 day. I have the following command and it fails with the message
The filename, directory name, or volume label syntax is incorrect.
Can someone help with the correct syntax?
Below is the command.
winscp.exe /ini=nul /log=C:\winscp\winscp.log /command "open sftp://account@ip_address -privatekey="C:\privatekey.ppk"" "put -filemask="*>=1D "D:\logs\* /linuxserver/logs/" "exit"
Re: Transfer files from Windows to Linux
You have the quotes wrong. And also there must be space after the quote before the D:\logs\*:
"put -filemask=""*>=1D"" D:\logs\* /linuxserver/logs/"
See https://winscp.net/eng/docs/commandline#syntax
If this does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
