Scripting "open" does not work
MarcelMonteny1
I try to use scripting for automatic transfers, but I'me not able to login with the script.
When I use the /console command and open manualy, the connection works good. But when I put this in a script I have to type the username, and this does not work.
Script:
open environment.lastname.surname.version:p1a2sswd@ns1.aprovider.com
What am I doing wrong?
It's quit a funny and very lang username.
Note:
Names are not for real!
Re: Scripting "open" does not work
You haven't written WHAT does not work. However I suppose that you are using version 3.8 beta that has bug making "open" command fail when a password is specified as its arguments. Please downgrade.
MarcelMonteny1
WHAT not work is that I don't get connection to the server.
Used version 3.7.6 build 306
