need to copy files from local directory to ftp
mnaveen
India
i m trying to copy in local directory to ftp directories using sychronize command
"D:\Program Files\WinSCP\winscp.com" /log="D:\eCP\winscp_log\test\winscp.log" /command ^
    "option batch abort" ^"open ftps://xxxxxxxxxxx%%2Fsupport@xxxxxx.com:%Password%@xxxxxxxxxxx.sharefileftp.com/BILLING/TEST" ^
"synchronize remote D:\Citrix ftps://xxxxxxxxxxx%%2Fsupport@xxxxxx.com:%Password%@xxxxxxxxxxx.sharefileftp.com/BILLING/TEST"  ^
    "exit"
but remote directory is not listing, please help me to fix this
Reply with quote E-mail
Re: need to copy files from local directory to ftp
The synchronize command takes a remote path only. Not a URL.
https://winscp.net/eng/docs/scriptcommand_synchronize
You are giving the URL to the open command already.
You also need to indent the line:
https://winscp.net/eng/docs/faq_batch_file#newline_escaping
    "synchronize remote D:\Citrix /BILLING/TEST"  ^
If this does not help, please post a session log file.
mnaveen
India
get command falinign the script
"synchronize local E:\expEDIum /temp_TM ^
> 2020-12-15 19:49:09.481 Script: synchronize local E:\expEDIum /temp_TM ^
< 2020-12-15 19:49:09.481 Script: Too many parameters for command 'synchronize'.
mnaveen
How to specify speed limit and resume tranfer options for put and get commands
I have large volume of data to tranfer to FTP, can you please help me to specifying speed limits and resume options.
mnaveen
India
i am copying files from ftp using get comamnd but tranfer aborted
    "open ftps://*****@itechws.com:%Password%@*****.sharefileftp.com -hostkey="******"" ^
    "get /ECC/* E:\ECC\" ^
< 2020-12-15 22:12:02.058 Copying files from remote side failed.
< 2020-12-15 22:12:02.058 Connection closed; transfer aborted.
what should to resume transfer and to speedup the downloads?
Re: i am copying files from ftp using get comamnd but tranfer aborted
