Trying to create a Powershell script that pulls new files
BlaaargPirate
I've been trying to create a PowerShell script that transfers all files created/modified within the past week, and places them in a folder. According to PowerShell, the script runs and finishes, no errors and PowerShell doesn't close. I came up with the following, based on a couple stackoverflow topics and reading stuff here.
# Load WinSCP .NET assembly
Add-Type -Path "C:\FilePath\WinSCP\WinSCPnet.dll"
# Set up session options
    Protocol = [WinSCP.Protocol]::Ftp
    HostName = "BlahBlah"
    UserName = "BlahBlah"
    Password = "BlahBlah"
try
    # Connect
    # Transfer files
   $remotePath = "\\LocalFilePath\*"
    $transferOptions.FileMask = "*>=7D"
   $session.GetFiles("/FTPFilePath/*.csv", $remotePath, $False, $transferOptions).Check()
finally
    $session.Dispose()
As I said, powershell stopped giving me errors, so didn't have anything to go off of on that front. I've tried reading some of the articles here, but being extremely new to not only this but scripting in general, I haven't been able to figure out what's wrong. I've tried some blind experiments (re-arranging stuff, using .Put instead of .Get, '<' instead of '>') but nothing happens. My guess is I'm using $transferOptions wrong, but I can't figure out the how/why. Any help would be appreciated. Thank you.
Re: Trying to create a Powershell script that pulls new files
