Install Winscp on a Windows RDS 2012 server with a winscp.ini file for multiply user
yzimmerman
Hello
How to install winscp on a windows rds server 2012 for multiple users
The user has to have is one winscp.ini for saving his settings
or grouppolicy
Re: Install Winscp on a Windows RDS 2012 server with a winscp.ini file for multiply user
Why do you want to use the INI file instead of the default registry?
yzimmerman
i understand your question
the challange is i am locking for a solution when you have multiply users on a windows rds enviroment and every users can save his settings on the system wihtout conflicting with other users..
the solution can be a HKCU user registry setting
or a ini file for every users.
