Synchronize -filemask and exclude empty directories (command line)
ttop
Ireland
I realise the below script is not correct as I have a few queries about how to move forward.
  • I am writing a script for file transfer synchronisation
  • I wish to sync my local directory with the remote directory but I don't want all the remote directory empty folders?
  • I also only want the most recent files available from the non-empty directories of the Remote end sync's into me local end?
  • I will schedule this .bat file once complete to run every 15 minutes
  • The below synchronisation still downloads the empty directories?
for /f "tokens=2 delims==" %%a in ('wmic OS Get localdatetime /value') do set "dt=%%a"
set "YY=%dt:~2,2%" & set "YYYY=%dt:~0,4%" & set "MM=%dt:~4,2%" & set "DD=%dt:~6,2%"
set "HH=%dt:~8,2%" & set "Min=%dt:~10,2%" & set "Sec=%dt:~12,2%"
set datestamp=%YYYY%%MM%%DD%
set CONN_SFTP_SVR="ftp://user:password!@10.10.10.10 hostkey=* -rawtransfersettings ExcludeEmptyDirectories=1"
:: I tried the '-rawtransfersettings ExcludEmptyDirectories=1' here, but I am not sure how to include this? ::
set LOCAL_DIR1="D:\A\B\C\D\E\"
set LOCAL_DIR2=""D:\A\B\C\D\A1\"
set LOCAL_DIR3=""D:\A\B\C\D\A2\"
set LOCAL_DIR4=""D:\A\B\C\D\A3\"
set REMOTE_DIR1="D:\A\B\C\D\E\"
set REMOTE_DIR2=""D:\A\B\C\D\A1\"
set REMOTE_DIR3=""D:\A\B\C\D\A2\"
set REMOTE_DIR4=""D:\A\B\C\D\A3\"
set file_pattern=*%datestamp%*statsfile.xml
"C:\Program Files (x86)\WinSCP\WinSCP.exe" /xmllog=D:\Logs\!Y!M!D_!T_LOGS.xml
"/script=D:\LOACTION\TheCommands.txt"
###################################This is my transfer#######################
##A new file arrives on the remote server every 15 minutes and I wan to collect the most recent one. I use >15N but maybe there is a better way?########
open %CONN_SFTP_SVR%
option batch abort
######Example of dir 2 only##########
synchronize local -filemask=%file_pattern%>=15N %LOCAL_DIR2% %REMOTE_DIR2%
close
ttop
Ireland
Thank you, I realise it is part of the synchronise command, but I could not get it to work that way. See below
option batch abort
cd %REMOTE_DIR2%
lcd %LOCAL_DIR2%
synchronize -rawtransfersettings ExcludeEmptyDirectories=1 -filemask=*.xml>=15N local
I get the below error
<?xml version="1.0" encoding="UTF-8"?>
<session xmlns="http://winscp.net/schema/session/1.0" name="tleacy@10.147.21.34 -hostkey=*" start="2020-12-11T09:48:14.646Z">
  <failure>
    <message>Unknown option 'ExcludeEmptyDirectories=1'.</message>
  </failure>
</session>
I tried this
option batch abort
get -rawtransfersettings ExcludeEmptyDirectories=1 -filemask=*.xml>=15N %LOCAL_DIR2% %REMOTE_DIR2%
and I got the below error
<session xmlns="http://winscp.net/schema/session/1.0" name="tleacy@10.147.21.34 -hostkey=*" start="2020-12-11T11:26:16.740Z">
  <failure>
    <message>Can't get attributes of file 'ExcludeEmptyDirectories=1'.</message>
    <message>File or folder 'ExcludeEmptyDirectories=1' does not exist.</message>
  </failure>
</session>
Re: Synchronize -filemask and exclude empty directories (command line)
You are probably using an old version of WinSCP that does not support the -rawtransfersettings. Make sure you use the latest version of WinSCP. If this does not help, please post a session log file, not the XML log.
Ashim
filemask error
Dear Martin,
I am also trying to synchronise using the WinSCP commands, but I do not succeed in synchronising the files from the server to my local drive:
REM Step2: Connect to FTP and synchronise all the files
"C:\Users\giyash\AppData\Local\Programs\WinSCP\WinSCP.com" ^
  /log="z:\Projekte\109797-TestfeldBHV\30_Technical_execution_Confidential\TP3\AP2_Aufbau_Infrastruktur\Infrastruktur_Windmessung\02_Equipment\01_Wartung_Messmast_GE-NET_DWG_20190226\Data\UpgradeData\sync_Metmast_upgrade.log" /loglevel=-1 /logsize=5*10M /ini=nul ^
  /command ^
    "open ftp://iwes_bhv:iwes2020#@172.25.5.231:48489" ^
    "synchronize local -filemask="*>60D" "z:\Projekte\109797-TestfeldBHV\30_Technical_execution_Confidential\TP3\AP2_Aufbau_Infrastruktur\Infrastruktur_Windmessung\02_Equipment\01_Wartung_Messmast_GE-NET_DWG_20190226\Data\UpgradeData\" ""/Intenso/LoggerRaw/"" "  ^
    "exit"
If I replace the filemask with *.* it works, but synchronises the whole folder, which I want to restrict to 60 days for example.
Re: filemask error
@Ashim: You have the quotes wrong. The simplest solution is to remove all intern quotes in the synchronize command, as none of them are needed:
    "synchronize local -filemask=*>60D z:\Projekte\109797-TestfeldBHV\30_Technical_execution_Confidential\TP3\AP2_Aufbau_Infrastruktur\Infrastruktur_Windmessung\02_Equipment\01_Wartung_Messmast_GE-NET_DWG_20190226\Data\UpgradeData\ /Intenso/LoggerRaw/"  ^
See also:
https://winscp.net/eng/docs/commandline#syntax
ashimgiyanani@yahoo.com
Filemask
Thank you for the prompt reply.
The quotes are placed rightly as they form a part of a batch script and the lines access WinSCP from the cmd command.
I got the script to work eventually, by enclosing the filemask in additional quotes. For example
-filemask=““*>60D““...
Hopefully, you can add this somewhere in the documentation as I couldn’t find this information anywhere
Re: Filemask
No, you do not have the quotes right. Though indeed, doubling the all internal quotes helps too. And the link I've posted in my previous response shows that! But again, the quotes are unnecessary as there are no spaces in your parameters.
Re: Filemask
Hi Martin,
Right said. It works with double quotes, but is unnecessary. I am not sure why, but my batch file keeps stopping at certain junctions after winscp is implemented. Do you have any recommendations, how I can resolve the issue?
REM syncing to z: drive
cd "c:\Program Files\OpenVPN\bin"
REM Step1: Connect to VPN
openvpn-gui --connect "mdex fixed.IP20 TCP.ovpn" --config_dir "c:\Program Files\OpenVPN\config" --silent_connection 1
    "open ftp://xxxx_abc:xxxxxxx@172.xx.x.xx:xxxxx" ^
    "synchronize local -filemask=*.* -neweronly "server_mirror\" ""/Raw/"" "  ^
   "close" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo WinSCP finished:Success
) else (
  echo Error
REM Step3- Disconnect openVPN
"c:\Program Files\OpenVPN\bin\openvpn-gui.exe" --command disconnect_all
REM Step 4- Copy newer files to a to_convert folder, delete 0kB files
rmdir "Path"
Re: Filemask
Sorry, no idea what you mean by "keeps stopping at certain junctions". Can you be more specific?
Though your batch file does even run WinSCP. So no surprise it does not work. There's no WinSCP.com anywhere.
MAXOHDA
Hi
synchronize local -transfer=binary -filemask=>1K "E:\Backup\SxHotSrv\Documents\"
it gets stuck on every file that has a size of 0.
how to solve the problem?
A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.
П(р)ервать, П(о)вторить, (П)ропустить, Пропустить (в)се: Пропустить
5dd1fcc9-102e-11ed-80d5-0 |         147 KB |   15,4 KB/s | binary | 100%
5dd880e1-c1da-11ec-80d4-0 |            0 B |   15,4 KB/s | binary |   0%
