Login/Session window takes a very long time to open
ajwilder
California
I have about 500 sites saved in the Login window. Over time, it's started taking longer and longer to open, and now takes at least 30 seconds for the window to open each time.
Using WinSCP 5.17.9 with Commander interface. Windows 10 Pro, i5-7600T processor, 32GB ram.
I've tried changing the Configuration storage from the registry to a custom ini file, but that hasn't helped.
Logging is disabled.
I am using a master password, however I turned that off and that did not help either.
Any ideas?
Thanks!
- Andrew
Re: Login/Session window takes a very long time to open
