Can't transfer - Treating files like they are directories
tjj
Version 5.17.19
Sometime this morning WinSCP stopped working properly.
It appears to be treating everything on the source side (left pane) as a directory. If I transfer a file(L->R) with an existing file on the R, I get an error code 4 (which I believe is indicating it's trying to copy a directory that already exists).
If I transfer a file(L->R) that does not already exist on the R, I get a code 267 (invalid directory name) and it creates a directory on the R with the same name as my file.
Error retrieving file list for "Z:\m...\foo.pdf\*.*".
System Error. Code: 267.
The directory name is invalid
Transfers from R->L seem to work.
Re: Can't transfer - Treating files like they are directories
Graywalker
Same issue
Relevant log entries:
. 2022-08-03 14:13:02.936 type=file;size=147456;modify=20140204234929.000;perms=awrfd; Profile.mdb
. 2022-08-03 14:13:02.936 type=file;size=1314816;modify=20120119001033.000;perms=awrfd; Support.mdb
. 2022-08-03 14:13:02.963 Source file timestamp is [2014-02-05T01:56:39.000Z], destination timestamp is [2014-02-05T01:56:39.000Z], will not overwrite
. 2022-08-03 14:13:02.963 Upload successful
* 2022-08-03 14:13:02.963 (ESkipFile)
. 2022-08-03 14:13:02.963 File: '\\server.mycompany.local\share\IntelliForms\Database\mdbDataTransfer.exe' [2011-09-07T18:10:44.000Z] [102400]
* 2022-08-03 14:13:03.779 (EOSExtException) Error retrieving file list for "\\server.mycompany.local\share\IntelliForms\Database\mdbDataTransfer.exe\*.*".
* 2022-08-03 14:13:03.779 System Error.  Code: 267.
* 2022-08-03 14:13:03.779 The directory name is invalid
. 2022-08-03 14:13:03.779 Asking user:
. 2022-08-03 14:13:03.779 Error listing directory '\\server.mycompany.local\share\IntelliForms\Database\mdbDataTransfer.exe\*.*'. ("Error retrieving file list for ""\\server.mycompany.local\share\IntelliForms\Database\mdbDataTransfer.exe\*.*"".","System Error.  Code: 267.","The directory name is invalid")
< 2022-08-03 14:13:03.779 Script: Error listing directory '\\server.mycompany.local\share\IntelliForms\Database\mdbDataTransfer.exe\*.*'.
< 2022-08-03 14:13:03.780 Script: Error retrieving file list for "\\server.mycompany.local\share\IntelliForms\Database\mdbDataTransfer.exe\*.*".
< 2022-08-03 14:13:03.780 System Error.  Code: 267.
< 2022-08-03 14:13:03.780 The directory name is invalid
* 2022-08-03 14:13:03.784 (ESkipFile) Error listing directory '\\server.mycompany.local\share\IntelliForms\Database\mdbDataTransfer.exe\*.*'.
* 2022-08-03 14:13:03.784 Error retrieving file list for "\\server.mycompany.local\share\IntelliForms\Database\mdbDataTransfer.exe\*.*".
* 2022-08-03 14:13:03.784 System Error.  Code: 267.
* 2022-08-03 14:13:03.784 The directory name is invalid
. 2022-08-03 14:13:03.791 Copying finished: Transferred: 0, Elapsed: 0:01:19, CPS: 0/s
. 2022-08-03 14:13:03.791 Script: Failed
. 2022-08-03 14:13:03.791 Script: Exit code: 1
. 2022-08-03 14:13:03.792 Disconnected from server
Command being run via batch file :
"put \\server.mycompany.local\share\IntelliForms -resumesupport=on -resume -preservetime -neweronly" ^
ftpes, if that helps.
Would adding -transfer=automatic help? (trying that now)
Re: Same issue
@Graywalker: Thanks for your report.
This issue is being tracked here:
Issue 2056 – File on local network share treated as folder when uploading
