WinSCP Crashing after trying to load directory
CullenHoffmann
Maryland
I am able to access the /<root> folder, however whenever I try to access any of the folders underneath this root folder, WinSCP will go into "Not Responding" mode, and crashes after several minutes. I am able to load these files using a different program (CyberDuck), so that tells me it's an issue with WinSCP and not with the folder structure.
I have tried several attempts to remediate this issue. I have restarted my computer, I have tried to log in to WinSCP without saved credentials, I have tried to install the latest version of WinSCP, and I have also tried to uninstall WinSCP and reinstall it with the same issue.
Re: WinSCP Crashing after trying to load directory
CullenHoffmann
Maryland
I have attached the log file privately. I think I did this correctly. Please let me know if I need to get the log file a different way.
Thank you!
  • AKIAXRCWAT6JQTNXG6E7@s3.amazonaws.com.log (108.42 KB, Private file)
Thanks. I have sent you an email with a debug version of WinSCP to the address you have used to register on this forum.
