Background Grey after restart
BlutVampir
When Starting SCP, the Background is Grey.
When I switch to dark mode, it got dark, back to light mode, it gets "white", which I want.
Restart programm, grey again.
I did a screen recording, please see attachment
I swiched from Registry settings to WinSCP.ini file, closed WinSCP and deleted the settingsfile. Restarted, same issue.
How can I solve that?
Description: Recording of the problem
Re: Background Grey after restart
Thanks for your report. What version of WinSCP is that? How are you starting WinSCP? With a desktop shortcut to a specific stored site?
BlutVampir
I did test it and Yes, its a specific site.
How can I remove that on that specific site?
I use a shortcode, but I can start diffrent sites with a shortcode which I dont have that issue.
Thanks for your help
BlutVampir
Versuin 5.17.9 Build 10905 - newest Version all the time.
I have the same Issue when:
Starting via KeePass Shortcode:
    "C:\Program Files (x86)\KeePass Password Safe 2\KeePass.exe" -entry-url-open -uuid:08CF216912E8934FA5CAF2088A2BC268', "C:\Program Files (x86)\KeePass Password Safe 2\"
    Manual via cmd://"{ENV_PROGRAMFILES_X86}\WinSCP\WinSCP.exe" sftp://{USERNAME}@xx.xx.xx.xx:22
BUT: I do have 1 laptop and 1 PC.
KeePass is on NAS Share, both use the same DB.
Both have the same Version of WinSCP.
I did save the config to winscp.ini on the laptop (I do not have the issue) overwritten the copy ion the PC, PC has still the issue.
I only have the issue on the PC. Not on my laptop.
Can I clean the registry somehow or reinitialize WinSCP That every config is gone?
I cannot reproduce the problem even with KeePass. I have sent you an email with a debug version of WinSCP to the address you have used to register on this forum.
