Newbie Question: "Batch PDF Uploads"
Bobby
I usually upload to my server from the command line, and Dreamweaver infrequently.
We have a new application to upload PDFs. The volume could grow to uploading about 250 to 500 PDFs daily.
Do you have a capability in your WinSCP client which enables me to upload the PDFs as a batch. Let's say I've got 250 PDFs in folder Origin1 on my C: drive [MS XP Home], and want to upload them to folder Destination1 on my server [FreeBSD].
Name001.pdf
Name002.pdf
Name003.pdf
Name250.pdf
Rather than uploading 250 times from the command line - ftp>put "Name001.pdf" through to ftp>put "Name250.pdf" – I'd like to be able to somehow use WinSCP and say "upload contents from Origin1 to Destination1." Then I could leave it, and work on something else.
If this is possible, how does the client deal with server timeouts?
Thank you for any replies,
Bobby
Re: Newbie Question: "Batch PDF Uploads"
You can do "put *.pdf" (to upload all PDF files from current directory) or "put X:\directory\" (to upload all files from specified directory). See examples in "help put".
Bobby
Thank you for your reply.
There is a revision to our process based on new information from our supplier - as follows:
The requirement is now to upload each PDF to its own folder. For example, the following PDFs:
Name001.pdf
Name002.pdf
Name003.pdf
Name250.pdf
Will be uploaded one PDF per folder, to the folders:
Destination1
Destination2
Destination3
Destination250
We do not have a preference to continue uploading from the command line.
Does your FTP client have the ability – either as a standard feature/function or via automation – to achieve the following, or similar, process?
For X=1, 250
Upload file NameX.pdf to folder DestinationX
Continue if X < = 250
Regards,
Bobby
Take any scripting language (Perl, PHP, etc.) and make script that generates upload script for WinSCP.
