WinSCP Synchronization Feature in .NET Code
aleagloan
Kansas
I am new to WinSCP so I am not sure how the "synchronization" feature works. I have the need to do file retrieval from another company's FPT site using SFTP three times a day at a certain time. I would like to use the "synchronization" feature to watch for file changes instead of using a scheduler. However, I do not know if I need to install the WinSCP.exe on the application server and have it running in the background all the time for it too work.
I install WinSCP using a nuget package for my .NET code. I was able to download a file from a test FTP site from another company. In other words, the GetFiles() worked.
I would really appreciate if you can guide me through this. Thank you.
Description: This file only downloads a file or files from another FTP site.
Re: WinSCP Synchronization Feature in .NET Code
Yes, you will have to. There's no API in FTP/SFTP to get notified about the changes. You have to proactively poll the server for changes. See https://stackoverflow.com/q/1277239/850848
Here is a PowerShell example of such code:
https://winscp.net/eng/docs/library_example_keep_local_directory_up_to_date
