Permission Denied(PublicKey) while open symlink on remote directory panel
Tamilarasan
Hi Team,
I unable to open symbolic link on remote directory panel using public key authentication but its working fine using password authentication.
Please any one help me out this problem.
Regards,
Tamilarasan.
  • Session.log (1.48 KB, Private file)
Description: Session Log
  • Capture.PNG (46.24 KB, Private file)
Description: Issue while open symlink directory on remote panel
Re: Permission Denied(PublicKey) while open symlink on remote directory panel
Please attach a full session log files from both scenarios (using the latest version of WinSCP).
Tamilarasan
Hi Martin,
I attached both session log files you requested.
Note: I masked (XXX) some sensitive information from logs.
Kindly review and update.
Regards,
Tamilarasan.
  • PasswordBased.log (17.47 KB, Private file)
Description: Password based authentication
  • KeyBased.log (18.41 KB, Private file)
Description: Key based authentication
Thanks for the logs. Though, I have no suggestion. I can only confirm, what you have claimed. Except for the authentication method, all other things equal, the results are different. It's indeed technically possible that you get different results with different authentication methods, but it's not usual. In any case, it seems to be server-side issue.
