Sequence of Close Session Close Connection in Server Mixed up
zerlauth@gmx.de
in my C#-Programm I have the following sequence:
    open session (Protocol.Sftp)
    put file
    close session
    dispose session
When I look into the log-file at the server I see
    open connection
    open session
    put file
    close session
    close connection
So far, so good
BUT
sometimes I find
    open connection
    open session
    put file
    close connection
    close session
Why does WinSCP send the commands sometimes in a wrong sequence?
Noone else uses the server, therefore I can be sure that there is no other session open on the server.
FTP-Log:
Nov 9 07:59:59 10.xx.xx.0 userxxx Connection from 10.xx.xx.0 port 47726 on 82.xx.xx.236 port 22
Nov 9 07:59:59 10.xx.xx.0 userxxx Accepted password for userxxx from 10.xx.xx.0 port 47726 ssh2
Nov 9 08:00:00 10.xx.xx.0 userxxx Starting session: subsystem 'sftp' for userxxx from 10.xx.xx.0 port 47726 id 0
Nov 9 08:00:00 10.xx.xx.0 userxxx session opened for local user userxxx from [10.xx.xx.0]
Nov 9 08:00:01 10.xx.xx.0 userxxx open "/ftp/incoming/TEST.DOC" flags WRITE,CREATE,TRUNCATE mode 0666
Nov 9 08:00:01 10.xx.xx.0 userxxx close "/ftp/incoming/TEST.DOC" bytes read 0 written 1211
Nov 9 08:00:01 10.xx.xx.0 userxxx [10.xx.xx.0|put|0|1211|0|0|0|2f6674702f696e636f6d696e672f5755542e444f43|]
Nov 9 08:00:01 10.xx.xx.0 userxxx set "/ftp/incoming/TEST.DOC" modtime 20201109-07:59:55
Nov 9 08:00:01 10.xx.xx.0 userxxx Connection closed by 10.xx.xx.0 port 47726
Nov 9 08:00:01 10.xx.xx.0 userxxx session closed for local user userxxx from [10.xx.xx.0]
Re: Sequence of Close Session Close Connection in Server Mixed up
Why do you think it's WinSCP issue? Or if it is an issue at all? It's probably just something about how the server logs the events. WinSCP cannot send "session close" after "connection close". How would it send it without having the connection opened?
