SynchronizationMode Local with FileMask
GerGer
philipines
HI i'am trying to automate sync. process of my local directory for .txt file only. but i'm having this error when trying to used the TransferOptions. help me pls.
WinSCP.Session.SynchronizeDirectories(WinSCP.SynchronizationMode, string, string, bool, bool, WinSCP.SynchronizationCriteria, WinSCP.TransferOptions)' has some invalid arguments
private void buttonReportsData_Click(object sender, EventArgs e)
    label1.Visible = true;
    try
        // Setup session options
            Protocol = Protocol.Ftp,
            HostName = "000.000.0.00",
            UserName = "HomeBoy",
            Password = "1234567",
            // Will continuously report progress of synchronization
            //session.FileTransferred += FileTransferred;
            // Connect
            session.Open(sessionOptions);
            while (true)
                //string filemask = "*.txt";
                buttonReportsData.BackColor = Color.DarkSeaGreen;
                buttonReportsData.Text = "Sync-Started";
                label1.Text = "FTP Sync process Started";
                TransferOptions transOp = new TransferOptions();
                transOp.FileMask = "*.txt";
                transOp.TransferMode = TransferMode.Automatic;
                // Synchronize files
                SynchronizationResult synchronizationResult;
                synchronizationResult =
                    session.SynchronizeDirectories(
                        SynchronizationMode.Local, @"C:\temp", "/folder1", false, transOp);
                // Throw on any error
                synchronizationResult.Check();
Re: SynchronizationMode Local with FileMask
The TransferOptions are 7th argument of Session.SynchronizeDirectories, not 5th.
https://winscp.net/eng/docs/library_session_synchronizedirectories
You either need to specific 5th and 6th arguments:
    false, SynchronizationCriteria.Time, transOp);
or use a named argument:
    options = transOp);
