Error: WinSCP.SessionLocalException: Element "group" not found in the log file
timrox
C# script in SSIS package
Uploading several files to S3
Line 6526 in WinSCPDebugLog file shows an XML GroupName but never finishes rest of XML.
Log files and script attached
Thank you for your help.
  • LogsAndScript.zip (110.92 KB, Private file)
Re: Error: WinSCP.SessionLocalException: Element "group" not found in the log file
Your actual problem is this:
Exception: System.TimeoutException: Timeout waiting for WinSCP to respond
You get the other exception only because you swallow the original one and try to call PutFiles once again over a timeouted session.
You get the timeout because you are transferring huge files. Set longer Session.Timeout.
