powershell $session.GetFiles
unterstreichung
New York
Hello WinSCP forums
I'm having a bit of a strange problem that I hope you guys can help me with.
I've produced a powershell script, which contacts an ftp server, deletes files based on one mask before downloading based on another.
The connection is made and my script deletes successfully, but when it comes to downloading I get "No such file or directory."
The relevant line reads
$downloadResult = $session.GetFiles(($remotePath + "ftpPINVOI*.*"), $localPath, $True, $transferOptions)
The filenames have a structure of ftpPINVOI_[timestamp]_[number].txt
Timestamp and number are just digits, nothing more.
winscp v577
WinServer 2008 R2
/HLM
Re: powershell $session.GetFiles
Make sure the $remotePath ends with a slash.
If this does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
