Unable to retrieve file information
NRANM
I'm running an FTP server on an ASUS RT-AC57U V3, and wanted to automate some tasks with a script. The mv command was not working from the script so I tried inputting the necessary commands manually using the console version of WinSCP, but it didn't work either. The stat command is also failing. WinSCP works fine with from the GUI, it's the commands/scripting that are not working.
I created an FTP server on a TP-Link Archer C2300, and commands are being executed properly, so I'm guessing ASUS are screwing things up with their FTP implementation.
I'm using the latest WinSCP version 5.17.8.
Is there any workaround for this? I don't want to have to buy a new router.
  • asuslog.log (4.96 KB, Private file)
NRANM
I have no clue why the SIZE command is failing. FTP is not a strong suite of mine. From the GUI everything looks and works fine.
If you need me to provide more logs or to perform some additional actions, just tell me what.
