grabbing the subdirectories that are 5 minutes old
anjali
anjali
Hello All,
I want to SFTP files and sub folders from my local path to remote path. My code is working fine if I want to transfer all the files and sub directories, but I only want to grab those sub directories that are 5 minutes old. In other words, I dont want to grab any sub directory that is very new. How can I achieve this. Below is my code:
transferOptions.TransferMode = TransferMode.Binary;
TransferOperationResult transferResult;
transferResult =
    session.PutFiles(@"K:\Documents\*", "/D:/Files/",  true, transferOptions);
// Throw on any error
transferResult.Check();
Any Help will be greatly appreciated.
Re: grabbing the subdirectories that are 5 minutes old
WinSCP cannot select folders based on a time, only files. Can you use the timestamps of contained files for the selection?
anjali
anjali
Yes, I can. How do I filter out the files that are 5 minutes old. I tried to use this mask, but it doesnt work:
transferOptions.FileMask = "*<=10N";
Below is my full code in C#:
string localPath = ConfigurationManager.AppSettings["localPath"];
string remotePath = ConfigurationManager.AppSettings["remotePath"];
    // Connect
    session.Open(sessionOptions);
    // Download files
    transferResult =
        session.PutFiles(@"K:\*", "/D:/eFiles/",  true, transferOptions);
    // Print results
    foreach (TransferEventArgs transfer in transferResult.Transfers)
        Console.WriteLine("Download of {0} succeeded", transfer.FileName);
any help will be highly appreciated.
So what does it do when "it doesn't work"? Consider posting a session log file, if appropriate, to document the problem.
