Suggestion: "Reading remote directory" - include the directory that is being read
precisonline
Colorado
Would it be possible to add a display of the directory path being read when "Reading remote directory" is happening during the login to a site? With the "use last directory" feature, I often don't remember which directory I was in last and some of these are massive. If I saw that it was left in one of these massive directories, I would know to stop the connection and change the configuration.
Re: Suggestion: "Reading remote directory" - include the directory that is being read
Thanks for the suggestion. I'll think about it.
I didn't want to pollute the window with additional information, most users do not care about. So the path displays only in a tooltip over the "Reading remote directory" message.
https://winscp.net/tracker/1916
precisonline
Showing Directory as tooltip above Reading Remote Directory
This will work just fine, thank you. Has there been a change to the Esc logic when loading that list; seems like it works a lot better now.
