Simple automation task
jjgurley
Selma, Oregon
I have a directory on my "client" and a similar director on a remote SFPT server.
I need to regularly (daily, hourly, etc) transfer all the new files to the server, then move them to a local subdirectory archive folder. Between transfers, the server will 'digest' the received files, although at an unpredictable rate.
My thought is I could use PUT to transfer all the files (not including subdirectories) to the server, then run an external script to move the files to the archive. I didn't notice an "exclude sub-directories" switch for PUT, and I didn't see a local move command in the scripting docs. If there's no sub-directory switch, I could move the archive up in the directory tree.
I've only been looking at the problem this morning, so don't rule out a rookie understanding and speed reading errors.
jjgurley
Selma, Oregon
Getting off to a pretty slow start. It appears from the help file that
"C:\Program Files (x86)\WinSCP\WinSCP.com" D:\scp.txt -ini=nul
should start winscp and fire up the script.
Instead I get the result
D:\>"C:\Program Files (x86)\WinSCP\WinSCP.com" D:\scp.txt
Searching for host...
Host "D" does not exist.
winscp>
The -ini argument doesn't seem to make a difference.
It is useless if I have to manually run winSCP and invoke the script.
jjgurley wrote:
The first page of the scripting manual is a little misleading.
Do you have any suggestion for an improvement?
