Winscp batch file running on demand or task scheduler
dadress
I have a batch file. When I run the batch file manually file downloads with correct size. Issue is when its run via task scheduler it seems to download with a wrong size. Any ideas?
Sample from log file when it runs via task scheduler
< 2020-10-14 19:15:02.773 Script: Synchronizing...
. 2020-10-14 19:15:02.773 Synchronizing local directory 'C:\AHRLogs\Downloaded\' with remote directory '/logs/', params = 0x1002 (NoConfirmation, Mirror)
. 2020-10-14 19:15:02.773 File: '/logs/LOG_us_rec_multi_replica_2020101419.SQB' [2020-10-14T23:15:01.000Z] [6144]
< 2020-10-14 19:15:02.773 Script: Local 'C:\AHRLogs\Downloaded' <= Remote '/logs'
. 2020-10-14 19:15:02.773 Copying "/logs/LOG_us_rec_multi_replica_2020101419.SQB" to local directory started.
. 2020-10-14 19:15:02.773 Binary transfer mode selected.
. 2020-10-14 19:15:02.773 Opening remote file.
> 2020-10-14 19:15:02.773 Type: SSH_FXP_OPEN, Size: 62, Number: 2051
< 2020-10-14 19:15:02.773 Type: SSH_FXP_STATUS, Size: 19, Number: 1796
. 2020-10-14 19:15:02.773 Discarding reserved response
< 2020-10-14 19:15:02.804 Type: SSH_FXP_HANDLE, Size: 13, Number: 2051
> 2020-10-14 19:15:02.804 Type: SSH_FXP_FSTAT, Size: 13, Number: 2312
< 2020-10-14 19:15:02.820 Type: SSH_FXP_ATTRS, Size: 29, Number: 2312
> 2020-10-14 19:15:02.820 Type: SSH_FXP_READ, Size: 25, Number: 2565
< 2020-10-14 19:15:02.914 Status code: 1
. 2020-10-14 19:15:02.914 6 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2020-10-14 19:15:02.914 Type: SSH_FXP_CLOSE, Size: 13, Number: 3588
< 2020-10-14 19:15:02.945 Type: SSH_FXP_STATUS, Size: 19, Number: 3333
. 2020-10-14 19:15:02.945 Preserving timestamp [2020-10-14T23:15:01.000Z]
> 2020-10-14 19:15:02.961 Script: exit
. 2020-10-14 19:15:02.961 Script: Exit code: 0
. 2020-10-14 19:15:02.961 Closing connection.
. 2020-10-14 19:15:02.961 Sending special code: 12
. 2020-10-14 19:15:02.961 Sent EOF message
Re: Winscp batch file running on demand or task scheduler
Can you please post logs for both scenarios? Also please elaborate on the "seems to".
