Connection Stopped Working
Longtime WinSCP user. Recently one of our saved connections that worked for years has stopped working. I have confirmed I am able to connect with other FTP clients. Steps I have taken:
Have tried Active Mode (Was setup and configured in Passive mode)
Reinstalled WinSCP
Rebuilt the connection
Reinstalled WinSCP
. 2020-09-30 10:13:44.197 -------------------------------------------------------------------------- . 2020-09-30 10:13:44.197 WinSCP Version 5.17.7 (Build 10640) (OS 6.3.9600 - Windows Server 2012 R2 Standard) . 2020-09-30 10:13:44.197 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\ . 2020-09-30 10:13:44.197 Log level: Normal . 2020-09-30 10:13:44.197 Local account: . 2020-09-30 10:13:44.197 Working directory: C:\Program Files (x86)\WinSCP . 2020-09-30 10:13:44.197 Process ID: 2064 . 2020-09-30 10:13:44.197 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" . 2020-09-30 10:13:44.197 Time zone: Current: GMT-4, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 03/08/20, DST End: 11/01/20 . 2020-09-30 10:13:44.197 Login time: Wednesday, September 30, 2020 10:13:44 AM . 2020-09-30 10:13:44.197 -------------------------------------------------------------------------- . 2020-09-30 10:13:44.197 Session name: * Inventory (Modified site) . 2020-09-30 10:13:44.197 Host name: ftp.*.com (Port: 21) . 2020-09-30 10:13:44.197 User name: * (Password: Yes, Key file: No, Passphrase: No) . 2020-09-30 10:13:44.197 Transfer Protocol: FTP . 2020-09-30 10:13:44.197 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec . 2020-09-30 10:13:44.197 Disable Nagle: No . 2020-09-30 10:13:44.197 Proxy: None . 2020-09-30 10:13:44.197 Send buffer: 262144 . 2020-09-30 10:13:44.197 UTF: Auto . 2020-09-30 10:13:44.197 FTPS: Explicit TLS/SSL [Client certificate: No] . 2020-09-30 10:13:44.197 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto . 2020-09-30 10:13:44.197 Session reuse: Yes . 2020-09-30 10:13:44.197 TLS/SSL versions: TLSv1.0-TLSv1.3 . 2020-09-30 10:13:44.197 Local directory: C:\FTP\* Inventory, Remote directory: /, Update: Yes, Cache: No . 2020-09-30 10:13:44.197 Cache directory changes: No, Permanent: Yes . 2020-09-30 10:13:44.197 Recycle bin: Delete to: No, Overwritten to: No, Bin path: . 2020-09-30 10:13:44.197 Timezone offset: 0h 0m . 2020-09-30 10:13:44.197 -------------------------------------------------------------------------- . 2020-09-30 10:13:44.212 Connecting to ftp.*.com ... . 2020-09-30 10:13:44.275 Connected with ftp.*.com, negotiating TLS connection... < 2020-09-30 10:13:44.353 220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- < 2020-09-30 10:13:44.369 220-You are user number 5 of 50 allowed. < 2020-09-30 10:13:44.369 220-Local time is now 14:13. Server port: 21. < 2020-09-30 10:13:44.369 220-This is a private system - No anonymous login < 2020-09-30 10:13:44.369 220-IPv6 connections are also welcome on this server. < 2020-09-30 10:13:44.369 220 You will be disconnected after 15 minutes of inactivity. > 2020-09-30 10:13:44.369 AUTH TLS < 2020-09-30 10:13:44.447 234 AUTH TLS OK. . 2020-09-30 10:13:44.619 Verifying certificate for "" with fingerprint *** and 20 failures . 2020-09-30 10:13:44.619 Certificate common name "*.*.com" matches hostname . 2020-09-30 10:13:44.634 Certificate verified against Windows certificate store . 2020-09-30 10:13:44.634 Using TLSv1.3, cipher TLSv1.3: TLS_AES_256_GCM_SHA384, 2048 bit RSA, TLS_AES_256_GCM_SHA384 TLSv1.3 Kx=any Au=any Enc=AESGCM(256) Mac=AEAD . 2020-09-30 10:13:44.650 TLS connection established. Waiting for welcome message... > 2020-09-30 10:13:44.650 USER *** < 2020-09-30 10:13:44.791 331 User *** OK. Password required > 2020-09-30 10:13:44.791 PASS ********** < 2020-09-30 10:13:45.181 230 OK. Current directory is / > 2020-09-30 10:13:45.181 SYST < 2020-09-30 10:13:45.259 215 UNIX Type: L8 > 2020-09-30 10:13:45.259 FEAT < 2020-09-30 10:13:45.353 211-Extensions supported: < 2020-09-30 10:13:45.353 UTF8 < 2020-09-30 10:13:45.353 EPRT < 2020-09-30 10:13:45.353 IDLE < 2020-09-30 10:13:45.353 MDTM < 2020-09-30 10:13:45.353 SIZE < 2020-09-30 10:13:45.353 MFMT < 2020-09-30 10:13:45.353 REST STREAM < 2020-09-30 10:13:45.353 MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*; < 2020-09-30 10:13:45.353 MLSD < 2020-09-30 10:13:45.353 PRET < 2020-09-30 10:13:45.353 AUTH TLS < 2020-09-30 10:13:45.353 PBSZ < 2020-09-30 10:13:45.353 PROT < 2020-09-30 10:13:45.353 TVFS < 2020-09-30 10:13:45.353 ESTA < 2020-09-30 10:13:45.353 PASV < 2020-09-30 10:13:45.353 EPSV < 2020-09-30 10:13:45.353 SPSV < 2020-09-30 10:13:45.353 211 End. > 2020-09-30 10:13:45.353 OPTS UTF8 ON < 2020-09-30 10:13:45.431 504 Unknown command > 2020-09-30 10:13:45.431 PBSZ 0 < 2020-09-30 10:13:45.509 200 PBSZ=0 > 2020-09-30 10:13:45.509 PROT P < 2020-09-30 10:13:45.603 200 Data protection level set to "private" . 2020-09-30 10:13:45.666 Connected . 2020-09-30 10:13:45.666 -------------------------------------------------------------------------- . 2020-09-30 10:13:45.666 Using FTP protocol. . 2020-09-30 10:13:45.666 Doing startup conversation with host. > 2020-09-30 10:13:45.666 PWD < 2020-09-30 10:13:45.744 257 "/" is your current location . 2020-09-30 10:13:45.744 Changing directory to "/". > 2020-09-30 10:13:45.744 CWD / < 2020-09-30 10:13:45.822 250 OK. Current directory is / . 2020-09-30 10:13:45.822 Getting current directory name. > 2020-09-30 10:13:45.822 PWD < 2020-09-30 10:13:45.900 257 "/" is your current location . 2020-09-30 10:13:45.916 Retrieving directory listing... > 2020-09-30 10:13:45.916 TYPE A < 2020-09-30 10:13:45.994 200 TYPE is now ASCII > 2020-09-30 10:13:45.994 PASV < 2020-09-30 10:13:46.072 227 Entering Passive Mode (54,70,172,***,168,177) > 2020-09-30 10:13:46.072 MLSD . 2020-09-30 10:13:46.072 Connecting to ***:43185 ... . 2020-09-30 10:14:01.197 Timeout detected. (data connection) . 2020-09-30 10:14:01.197 Could not retrieve directory listing * 2020-09-30 10:14:01.244 (EFatal) **Lost connection.** * 2020-09-30 10:14:01.244 Timeout detected. (data connection) * 2020-09-30 10:14:01.244 Could not retrieve directory listing * 2020-09-30 10:14:01.244 Error listing directory '/'.
