Synchronization without blocking the application
PawelGIX
It would be great if we had the option for this window to act as a panel. So that you can dock them. Or set it in some other way so that it does not block the use of the application
Re: Synchronization without blocking the application
The latest version of WinSCP has "Start in New Window" command in the Start button drop down menu.
