PowerShell Script Hanging
Simpuhl
La Mirada, CA
I put together a script that works fine, it's setup as a scheduled task but after X amount of runs it will randomly hang. Once the hanging starts, it continues until I reboot the server. I cannot figure out why. I can take the same script and run it on another PC and it works without any issue but will eventually hang the same way. I can't tell if its a bug with WinSCP, PowerShell, or the script. I feel like if the previous sessions aren't being disposed correctly or something? To be honest I have no clue. It just hangs in the task scheduler or if I run it manually.
Here is the part of the log that the script just get's stuck.
. 2020-09-10 08:00:20.356 Getting real path for '/'
> 2020-09-10 08:00:20.356 Type: SSH_FXP_REALPATH, Size: 10, Number: 272
< 2020-09-10 08:00:20.403 Type: SSH_FXP_NAME, Size: 49, Number: 272
. 2020-09-10 08:00:20.403 Real path is '/USERNAME'
. 2020-09-10 08:00:20.403 File: 'C:\WinSCP Scripts\Temp2\XXXXX.xml' [2020-09-09T20:37:08.500Z] [75239]
. 2020-09-10 08:00:20.403 Copying "C:\WinSCP Scripts\Temp2\XXXXX..xml" to remote directory started.
. 2020-09-10 08:00:20.403 Binary transfer mode selected.
. 2020-09-10 08:00:20.403 Opening remote file.
> 2020-09-10 08:00:20.403 Type: SSH_FXP_OPEN, Size: 62, Number: 515
< 2020-09-10 08:00:20.465 Type: SSH_FXP_HANDLE, Size: 33, Number: 515
> 2020-09-10 08:00:20.465 Type: SSH_FXP_WRITE, Size: 32813, Number: 1030
. 2020-09-10 08:00:20.465 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2020-09-10 08:00:20.465 Type: SSH_FXP_CLOSE, Size: 33, Number: 1796
> 2020-09-10 08:00:20.465 Type: SSH_FXP_SETSTAT, Size: 58, Number: 777
. 2020-09-10 08:00:36.870 Waiting for data timed out, asking user what to do.
. 2020-09-10 08:00:36.870 Asking user:
. 2020-09-10 08:00:36.870 **Host is not communicating for 15 seconds.
. 2020-09-10 08:00:36.870 Wait for another 15 seconds?** ()
< 2020-09-10 08:00:36.870 Script: Host is not communicating for more than 15 seconds.
< 2020-09-10 08:00:36.870 Still waiting...
< 2020-09-10 08:00:36.870 Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
< 2020-09-10 08:00:36.870 Warning: Aborting this operation will close connection!
. 2020-09-10 08:00:39.949 Data has arrived, closing query to user.
. 2020-09-10 08:00:39.949 Network error: Software caused connection abort
. 2020-09-10 08:00:39.949 Connection was lost, asking what to do.
. 2020-09-10 08:00:39.949 Asking user:
. 2020-09-10 08:00:39.949 Network error: Software caused connection abort ()
< 2020-09-10 08:00:39.949 Script: Network error: Software caused connection abort
The task errors with
Task Scheduler did not launch task "\Script" because instance "{654b6dbf-fd19-4a8c-8ce5-7b42590d11e6}" of the same task is already running.
Here is the script, I removed any identifying info
# Load WinSCP .NET assembly
# Set up session options
    HostName = "xxxx.com"
    UserName = "XXXXXXSFTP"
    SshHostKeyFingerprint = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
    SshPrivateKeyPath = "C:\Program Files (x86)\WinSCP\SSH Key\XXXXXXXX\XXXXXXXXXXXKey.ppk"
    $remotePath = "/"
    $localPath = "C:\WinSCP Scripts\XXXXXXXXXXXX\Temp2\*"
$uploadSession = New-Object WinSCP.Session
$uploadSession.SessionLogPath = "C:\WinSCP Scripts\XXXXXXXXXXXXt\TEST-Upload.log"
try
    # Connect
    $uploadSession.Open($sessionOptions)
    # Upload files
    $transferOptions.OverwriteMode = [WinSCP.OverwriteMode]::Overwrite
    #Upload Files - localPath, remotePath, remove (true, deletes source local file(s) after a successful transfer)
    $transferResult = $uploadSession.PutFiles($localPath, $remotePath, $False, $transferOptions)
    # Print results
    foreach ($transfer in $transferResult.Transfers){
    Write-Host ("Upload of {0} succeeded" -f $transfer.FileName)
    #Copy-Item $transfer.FileName -Destination "E:\XXXXXXXXXXXXXXXXXXX"
    #Move-Item $transfer.FileName -Destination "\\XXXXXXXXXXXXX\Archive"
    $transferResult | Out-File "C:\WinSCP Scripts\XXXXXXXXXXXX\TEST-TransferResult.log"
    $transferResult.Transfers | Out-File "C:\WinSCP Scripts\XXXXXXXXXXXX\TEST-Transfers.log"
    # Throw on any error
    $transferResult.Check()
finally
    $uploadSession.Dispose()
    exit 0
catch
    exit 1
Simpuhl
La Mirada, CA
So I think its actually a Windows Server issue because the hang-up also occurs when manually moving the file using the WinSCP GUI. If I perform the action from another server it uploads without any issues. When it does let me drag it over, the script also works without hanging.
I am using the latest version of WinSCP.
Any idea
Simpuhl
La Mirada, CA
Thank you,
I may not get another chance to test this as I already moved the scripts to another server. I will run the debug and email the zipped trace file if I manage to reproduce it. I am working with production files and when they are uploaded or downloaded a bunch of things happen after that so it's hard for me to "test".
PS:
I also noticed the file will hang in the GUI also once the problem starts. So basically even if I manually upload it will show those same errors in the GUI version. If it happens again on this new server I'll try to take some screenshots.
So use the debug version for the GUI.
Simpuhl
La Mirada, CA
Ok, so the script stopped working and I ran the DEBUG version of the GUI. These are the errors I get when trying to upload a file. Once the error happens, it happens in both GUI and PowerShell script. No idea what causes it...
3 Screenshots and trace log have been attached.
I appreciate any help
  • 3.png (77.91 KB, Private file)
Description: Third error
  • 2.png (56.85 KB, Private file)
Description: Second error
  • 1.png (78.11 KB, Private file)
Description: First error
Simpuhl
Maximum attachment is 3, tried to attach trace log separately but file size is too large.
