Connection time out
pbland
Illinois
Connection time out
I'm trying to connect to my AWS server, but getting a time-out error. I use to be able to connect via WinSCP so I can't figure what has changed. My old laptop use to work, but not now and I just got a new laptop and it also has the issue. My new laptop had McAfee installed so I turned off the firewall just to see, but same problem. I also tried with FileZilla and same. Here is some of the log:
. 2020-09-08 19:42:35.568 Looking up host "ec2*********.compute-1.amazonaws.com" for SSH connection
. 2020-09-08 19:42:35.627 Connecting to ****** port 22
. 2020-09-08 19:42:56.635 Failed to connect to ******: Network error: Connection timed out
. 2020-09-08 19:42:56.637 Knocking FTP port.
. 2020-09-08 19:42:58.701 FTP port did not open.
* 2020-09-08 19:42:58.767 (EFatal) Network error: Connection to "ec2-*******.compute-1.amazonaws.com" timed out.
Any suggestions on what to try would be appreciated.
Re: Connection time out
It does not look like a local issue then. Either your network is blocking the connection or the server is not available. Not a problem, we can help with here.
