SFTP, Remote side unexpectedly closed network connection
JohnWis
WinSCP version 5.17.6
Worked with version 5.9.3
Windows server 2016 (in Citrix)
SFTP
Using the GUI
Error:
or:
Network error: Software caused connection abort
When setting up a connection to a Linux server, an error occur, connection can't be establised.
With the old version of WinSCP there is no issue to connect to these Linux servers, It is not 1 server but a pool of servers not working.
The WinSCP client (old en new) are running on a XenApp environment.
Description: 3 sessions, all failed but with 2 different messages
Re: SFTP, Remote side unexpectedly closed network connection
Can you post a log file of a successful session from the old version of WinSCP?
Thanks for the log. It didn't reveal anything useful though. Did you have an access to server-side logs? Don't you need to whitelist the new version somehow in your "XenApp environment"?
JohnWis
The log file from the linux server gives this message:
2020-09-23T10:47:35.129652+02:00 TController-Databus01-P-ACC sshd[348917]: fatal: No supported key exchange algorithms found [preauth]
Sshd_config server
Ciphers aes128-ctr,aes192-ctr,aes256-ctr
KexAlgorithms diffie-hellman-group-exchange-sha256
MACs hmac-sha2-256,hmac-sha2-512
And WinSCP should support this, but is this still in the current release
https://winscp.net/eng/docs/tls_ciphersuites
JohnWis
We already did
Version 5.9.3 ok
Version 5.10 Nok
Version 5.17.6 Nok
Do you want us to try the versions between 5.9.3 and 5.10?
Yes please.
JohnWis
Tested again
Version 5.9.6 is OK
Version 5.10.4.RC NOK
Version 5.11 is NOK
So there is a difference after version 5.9.6
JohnWis
What should we do to analyse or solve if this is the problem we have.
Upgrade your OpenSSH installation.
Or, if you register, I can send you a copy of WinSCP that does not trigger the wrong rule.
JohnWis
I just registered, can you send me a copy of WinSCP that does not trigger the wrong rule.
JohnWis
Hello, in the past I get from you a changed version of WinSCP without the issue, can you give us a new updated mobile version without the issue?
I have sent you the modified version only for your "analysis", if you indeed suffer from the referenced problem. It was not meant to be a solution. The solution is to upgrade your OpenSSH installation.
Emma 1989
Can you please send this to me also I cannot get it to work for me at all- emma181111@hotmail.com
@Emma1989: See my answer to @JohnWis above:
