Interface question
danb3
NY
Interface question
When I open WinSCP how can I see a list of the connections I have defined? This used to be visible on the left side of my screen.
Re: Interface question
Not sure what "left side" you mean. WinSCP cannot display the connection list on the main window (and it never could).
Maybe you are have turned off Login dialog from automatically popping up on the start?
https://winscp.net/eng/docs/ui_pref_window
See also WinSCP suddenly opens with two local panels with seemingly no option to open a connection to my server. What do I do?.
